2/22/2024 12:06 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello paul124 Do you have set up your CA and certificate set up in WinCC Unified certificate manager for the webserver? (LINK) Check also if you have installed the latest Updates for your TIA Portal Version and also for the WInCC Unified PC RT (Which is also used for the Simulation) Bye Murof |
