1/31/2025 7:34 AM | |
Joined: 1/21/2013 Last visit: 2/8/2025 Posts: 3524 Rating:
Hi djpiky, My first assumption would be that your script has a bug and is not reaching the line of code that should change the visibility. In general, the simulation should work as well as it does on the device. However, this will not be the case if you are using device-specific functionality that cannot be simulated. However, on a PC you can use the script debugger. I am sure this will help. Kind regards |
