11/29/2021 9:51 AM | |
Joined: 2/13/2017 Last visit: 1/28/2023 Posts: 2 Rating:
Hi, I had install a tia portal v17 at vmware and tried to login and this time it works. I had open runtime manager and on user management tab, when i click start local user management, it show " The JSON file is not correctly formatted" (see attached photo 2) but in vmware runtime manager show " local user management running (see attached photo 3). Is it got related with settings or other possibility? Attachment123.zip (84 Downloads) |
11/29/2021 3:19 PM | |
Joined: 3/3/2021 Last visit: 1/2/2023 Posts: 262 Rating:
Hello, I had a similar problem with the JSON file and contacted technical support. They provided me with the following PDF. I hope it helps you. with best regards Fred AttachmentWorkaround_Unexpected_Problem.pdf (376 Downloads) |
