6/22/2023 4:30 AM | |
Joined: 12/18/2021 Last visit: 8/28/2023 Posts: 3 Rating:
Occasionally those disconnected tags will be reconnected |
6/22/2023 7:22 AM | |
Joined: 2/17/2020 Last visit: 9/29/2023 Posts: 875 Rating:
Hi, Configuration should be OK, since sometimes problematic OPC tags connect to the OPC Server. However, it does not hurt to review the manual: V18 Unified manual - WinCC Unified OPC UA client On the other hand, I would recommend updating both the TIA Portal (engineering software) and the Unified PC V18 (Runtime) to the latest Update available. Below are the download links: Updates for STEP 7 V18, S7-PLCSIM V18 and WinCC V18 - Update 1 Updates for SIMATIC WinCC Unified PC Runtime V18 - Update 1 SR2 |
If this post helped you in any way, please rate it positively. |
