10/14/2024 10:02 AM | |
Joined: 5/6/2022 Last visit: 2/10/2025 Posts: 551 Rating:
Hi AutoGen_7381050, In this case, I have encountered this message and the problem was that the server had no memory left. The hard disk of multiuser server was full. After deleting data on the disk and freeing up space it worked again. Could you please check that this is not the problem? Best regards!
10/14/2024 10:26 AM | |
Joined: 4/5/2024 Last visit: 11/22/2024 Posts: 13 Rating:
I will contact my collegue and verify that |
