4/30/2013 4:27 PM | |
Posts: 10 Rating:
Hello all, I have problem with display of comment in short-term archive list. If an alarm view is switched to pending alarms (alarm list), the comment is correctly displayed in column with additional text, as it is configured. After switch to archive (short on long-term), only icon in comments column signalised, that this alarm have filled the comment, but in additional text column is not any text. Does anyone have similar problem or some solution? In attachment I join the preview of this problem. AttachmentWinCC-komentar k alarmu.pdf (273 Downloads) |
5/3/2013 4:19 PM | |
Posts: 3037 Rating:
Hello, You can use this @103%s@ in an user text block in your message. Then you see the comment in the short on long-term view. How do you display or print the content of the comments dialog box (comment, computer, author)? Tweety |
5/6/2013 3:32 PM | |
Posts: 3037 Rating:
Hello, I can not see your problem in my project. I can see the comment in the alarm list and in the archive (short-term mode). I use WinCC V12. Tweety |
