4/11/2013 2:15 PM | |
Posts: 3037 Rating:
Hello Davids, You start a support request at your installation problem with WinCC V12. Tweety |
5/27/2013 2:36 PM | |
Posts: 3037 Rating:
Hello, You can not use WinCC V11 and WinCC V12 on the same PC. http://support.automation.siemens.com/WW/view/en/64847781 Tweety |
5/28/2013 2:28 PM | |
Posts: 3 Rating:
Tweety, Yes I know, that is why i said i uninstalled V11. I only have V12 installed and i get this error. |
5/29/2013 11:09 AM | |
Posts: 3037 Rating:
Hello, You should check if you remove the WinCC V11 and STEP 7 V11 completely. You can see this under control panel > programs and features. Tweety |
1/26/2016 11:59 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4782 Rating:
New question published by HTrebilcock is split to a separate thread with the subject WinCC V13 prof installation error. Best regards |
