5/4/2014 1:06 PM | |
Posts: 515 Rating:
hi, try update it to the latest version and see whether the problem still persists
5/4/2014 2:57 PM | |
Posts: 150 Rating:
The version is WinCC V12 prof SP1. I think it is the latest version. |
5/6/2014 7:43 AM | |
Posts: 1299 Rating:
Hello, did you also install latest updates? WinCC Runtime Professional: http://support.automation.siemens.com/WW/view/en/80461043 WinCC Engineering: http://support.automation.siemens.com/WW/view/en/78683919 Do you use the graphics with different resolution? In this case it could increasethe performance if you change the resolution of the original files instead of changing it in wincc. K!ke |
5/10/2014 6:09 PM | |
Posts: 150 Rating:
I think such limitations in a SCADA in 2014 is just unucceptable. Totally disapointed. |
