2/7/2023 11:32 AM | |
Joined: 1/21/2013 Last visit: 3/22/2023 Posts: 1549 Rating:
Hi eurodata, can you provide further information about the error you receive? For writing files like in the OLE example, you can also use the "WriteFile" method. Kind regards |
2/7/2023 11:55 AM | |
Joined: 12/14/2016 Last visit: 3/13/2023 Posts: 4 Rating:
Hi Stefan The error is: ,Invalid object member: OLEAutomation in line 2, in column 25,,,12:32:44 PM In any case, I am not interested in the specific functionality of writing to a text file. But the possibility of using OLE automation technology in a unified pc runtime. This would allow me to use existing working components, that I already have. |
2/7/2023 12:38 PM | |
Hi Eurodata, as far as I know, OLEAutomation is not available in TIA Portal V18 and the OLEAutomation chapter should be removed from the documentation by the responsible person. You may want to create a support request to verify this information. Kind regards |
