3/14/2006 5:13 PM | |
Posts: 3149 Rating: (171)
Hi, in this forum there has already been a discussion about tools for diagnosing WinCC scripts: /tf/WW/en/Posts/2548 You should check the entries in your WinCC log files on your Server and Clients as well: ..\siemens\wincc\diagnose\... How much diskspace is available? How much RAM is available => task manager? Do you e.g. use option "storage" (and try to export large amounts of data at this time)? Are any other applications running on your Server - except WinCC? Which other software is installed on your server? Did you a lot of C-scripting? nemo |
3/21/2006 9:05 AM | |
Posts: 1084 Rating: (72) |
Thanks for sharing! |
