9/21/2006 1:19 PM | |
Posts: 3149 Rating: (171)
Hi I am not too sure whether I got your problem, but does this FAQ answer your questions?? http://support.automation.siemens.com/WW/view/en/15350783 nemo |
9/22/2006 9:28 AM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating: (151)
As you have found, the Tagname System Block does not work yet. The help file states that this is included for future use! So you have two options : 1) Use an ODK function to get the alarm details, including the tagname * 2) Create a User Text Block that contains the tagname. You can do this easily using the Excel Configuration Tool. Just export your alarms to Excel and copy the MessageTag column to the User Text Block column. * The ODK is an option for WinCC. http://www.siemens.com/wincc/options |
