6/25/2009 1:37 PM | |
Posts: 22 Rating: (0) |
Hi Miro79, Yes, I found this as well... More info is in the IndustrialX manual You can find it here: http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=29489481&caller=view Click the "Info" on the right (NOT "display" or "download") A popup will show you the available downloads, also for IndustrialX This manual won't help you that much, but in the IndustrialX package itself there area fewVB.NET samples as well. Writing to tagslooked not that straightforward to me. IndustrialX takes some of the handling for this (as setting the property of the control with the tag attached obviously does not work). In the samples you can see some additional stuff that handles tagwriting (and other things) Still it's quite a hussle and I decided to make all in VB.NET and unfortunately not use WinCC, because the advantage was almost gone in my case. Maybewas also my lack of understanding of the IndustrialX package and the .NET platform as well...However support on this seems to be more or non-existent and for sure not in the Netherlands. Maybe it can help you...maybe not, but this is my experience sofar. Goodluck! |
