11/4/2022 12:50 PM | |
Joined: 8/3/2009 Last visit: 4/28/2025 Posts: 15368 Rating:
Hello umutorkan a float datatype in SQL should be a Real datatype in HMI -> LINK Try a real Tag. And you can ry to check if the sql statement gives back a propervalue with the systemfunction ShowSystemAlarm in the script. Then you see in the alarm view if the value comes back as you need. bye Murof |
