2/13/2007 9:31 AM | |
Posts: 3149 Rating:
Hi for WinCC WebNavigator you need an extra CD, it´s not shipped with your WinCC CD https://www.automation.siemens.com/hmi/html_76/products/software/wincc_optionen/navigator.htm?HTTPS=REDIR nemo |
2/13/2007 12:26 PM | |
Posts: 1275 Rating:
For WebNavigator, as you may have seen, you need to purchase a separate license, which is configured by the amount of web clients to be connected simutaneously. Also.. if you check compatibility between WinCC and WebNavigator here, you'll see that WinCC v6.0 SP4 is only compatible with WebNavigator v6.1 SP1. |
