7/30/2007 6:56 PM | |
Posts: 19 Rating: (0) |
Hi, Does anybody know if WinCC V6.2 can work on "Windows 2003 server 64-bit version" or should I use the 32.bit version? I have seen technical documents like: http://support.automation.siemens.com/WW/view/en/8795716 but they don't specify anything about the 64-bit/ 32-bit versions. I guess if I could use the 64-bit version, the performance of my application would be much higher, wouldn't it? Thanks, José |
Last edited by: O_Moderator at: 9/16/2010 3:10 PMlink edited Last edited by: Heypermann at: 30.07.2007 18:59Last edited by: Heypermann at: 30.07.2007 18:58Last edited by: Heypermann at: 30.07.2007 18:57 |
7/30/2007 7:27 PM | |
Posts: 168 Rating: (49) |
Just DON'T do it! http://support.automation.siemens.com/WW/view/en/21927773 |
