7/27/2012 12:31 PM | |
Posts: 378 Rating:
Hello, did you really searched carefully on the support site It took me less than two minutes to find information about the compatibility of WinCC flexible and Step7 prof. And my results are that it depends on the SPs you have, With the newest SPs these softwares are compatible. About SIMATIC Logon i am not sure, because they don´t talk about 32bit or 64bit just about windows 7 (http://support.automation.siemens.com/WW/view/en/44889581) Best regards Bilao |
7/27/2012 1:00 PM | |
Joined: 5/28/2008 Last visit: 4/22/2025 Posts: 4520 Rating:
Hello, Please useCompatibility Toolto know compatibility between MS OS and SIMATIC software. Hope this helps
Ayman Elotaify |
7/27/2012 2:04 PM | |
Joined: 8/25/2005 Last visit: 3/21/2025 Posts: 1162 Rating:
Hello memet, I'm not a specialist about versions, ... But I searched for "SIMATIC Logon Windows 64 Bit" and found a delivery release SIMATIC Logon V1.5 Released for Delivery. Checking the "last" information about SIMATIC Logon V1.4 (SIMATIC Logon V1.4 Now Available with SP3) nothing about Windows 64 Bit is written. And, it is nearly 2 years old So I would say, that there is no statement that your version is compatible. The actual one is compatible. And the last one, ... it is a licens. Am I right? Good luck Sabine |
7/28/2012 12:01 AM | |
are compatible with Windows 7 64 bit or not? Hello,
Hope this helps. |
Ayman Elotaify |
