11/26/2019 12:20 PM | |
Joined: 9/9/2014 Last visit: 1/25/2023 Posts: 237 Rating:
Hi! So what is the question? If about a wire break, then look at the topics below (a search on the forum will give a result): How do handle wire break detection? How to do Digital Input Wire Break diagnostic In the simple case, you need to make sure that according to the user's manual on your devices - everything is connected correctly (24 volts and so on) In a general sense, this error just means that you have nothing connected to the analog module ... check the settings of the analog block - diagnostic of wire breaks (you can disable this function in the settings) Also, for a better understanding of your problem, you can send messages from the diagnostic buffer of the PLC, and we will tell you what happened) |
Best Regards |
