11/28/2011 2:05 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Please note that the 332 is anlog output only. The right way to connect it is in this manual and depends on theMLFB (the s7332-xxxx-xxxx number)you have there. Manual can be found here: http://support.automation.siemens.com/WW/view/en/8859629 If you still have problems then mention the MLFB. Regards, Marcjan |
Problem solved? |
11/28/2011 2:34 PM | |
Posts: 30 Rating:
Thanks very much Marcjan. Much appreciated |
