1/3/2006 10:25 AM | |
Joined: 9/23/2005 Last visit: 9/11/2024 Posts: 4347 Rating: (1445) |
Hi, A good first approximation to work memory and load memory is compare to a PC: Work memory of a PLC is like a RAM of a PC; load memory of a PLC is like a HD of a PC. Detailed information can be found in FAQs: http://support.automation.siemens.com/WW/view/en/7302549 and http://support.automation.siemens.com/WW/view/en/7302326 You can find the size of Work and Load memory of your project in the properties of tab “Block” of your project (in Simatic Manager). In same way the size of a block can be found in your properties. |
Denilson Pegaia |
This contribution was helpful to6 thankful Users |
1/9/2006 12:44 PM | |
Joined: 9/1/2005 Last visit: 8/12/2024 Posts: 4104 Rating: (195) |
Here you will find the link to the thread of Pegaia: Tomb Rule for estimation of memory occupation in SIMATIC PLC. CS Moderator |
