7/27/2006 9:13 AM | |
Posts: 3149 Rating: (171)
Hi, for getting data from other SQL-databases you could use the option connectivity pack. http://support.automation.siemens.com/WW/view/en/21288784 https://www.automation.siemens.com/hmi/html_76/products/software/wincc_optionen/connectivity-pack.htm Unfortunaltely there is not too much information avaible on the net, so you should contact your local siemens automation dealer. nemo |
7/27/2006 11:25 AM | |
Hi connecty pack is providing an interface to other databases and to your WinCC database (in both directions). Using non-Siemens ActiveX/OCX is in principle possible, but upto the user/you to ensure, that these OCX will not harm your performance, they certainly are NOT PCS7 systemtested. http://support.automation.siemens.com/WW/view/en/9927882 Check your WinCC online help for "web navigator ocx" nemo |
