6/18/2019 3:18 PM | |
Joined: 8/10/2017 Last visit: 6/6/2024 Posts: 22 Rating:
Hi, I'm trying to write on one of the slave drives parameter p1511 so I will be able to be move them independently via HMI .. I'm tying to use _writedriveparamater command However, I'm not sure where to find the values of : -Parameter Number : isn't 1511 ? -Logaddress : I try to use what I found on HW config Any help will be appreciated Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/19/2019 09:53:20New subject after splitting |
6/19/2019 9:59 AM | |
Joined: 5/12/2006 Last visit: 4/24/2025 Posts: 22624 Rating:
Hello, which slave? which CPU? Christoph |
6/19/2019 10:26 AM | |
Hello, ok can you give a screen with which paramters you call the function? regards christoph |
6/19/2019 10:34 AM | |
Please see attached,
6/19/2019 10:56 AM | |
Many thanks, Do I also need to set ioID to Output ? |
6/19/2019 11:41 AM | |
hello, you must use the startadress (628) regards Christoph |
