8/7/2017 9:05 AM | |
Posts: 1368 Rating:
Hello, For the ID parameter you should use the Modul Acces Point HW- ID. It is also possible to use the HW-ID of the cyclic telegram of the drive object. Have a look here: https://support.industry.siemens.com/cs/ww/en/view/109743977 theres an example, which seems perfect for you. Title: "SINAMICS V: Acyclic communication between SIMATIC S7-1500 and SINAMICS V90 via PROFINET"
8/7/2017 9:12 AM | |
Posts: 29 Rating:
This example seems to have everything.. It does not though. But I will try and check it again. thank you. |
8/7/2017 9:27 AM | |
Posts: 29 Rating:
Posts: 29 Rating:
11/15/2017 11:53 AM | |
Joined: 2/5/2015 Last visit: 12/2/2024 Posts: 4 Rating:
Pls know me how define the index number?
11/16/2017 10:26 AM | |
hi, have a look in the manual of the SFC/SFB: System Software for S7-300/400 System and Standard Functions Volume 1 and Volume 2 Chapter 8.1 and 8.2 are describing how the blocks work. You find the structure of the Records in the relating manual of the module you want to read/write. for example, the S7-300 modules, you find it in the manual, chapter A hope this helps, regards, |
FCK WAR! |
