12/16/2011 10:44 PM | |
Posts: 1 Rating:
Hi, It seems you have broken cable/encoder, it is your encoder thats at fault, your drives not recieving it's signal some how.... hope this helps. |
9/10/2012 7:37 AM | |
Posts: 21 Rating:
hi Kindly check encoder cable with some other drive if that drive show some fault cable is faulty , else you need to replace the encoder. Regards Nitin Dangwal |
1/3/2018 2:30 PM | |
Joined: 9/1/2005 Last visit: 4/10/2025 Posts: 4113 Rating:
New question published by samiraj is split to a separate thread with the subject Two axis with several alarms. Best regards |
