12/15/2015 6:33 AM | |
Joined: 5/12/2006 Last visit: 4/29/2025 Posts: 22627 Rating:
Hello, this is no problem of SIMOTION this is a problem of the Panel. To load a Panel with a Routing connection you must use a Comfort Panel in TIA, with a Basic Panel you can't load or go Online with a Routing Connection. https://support.industry.siemens.com/cs/ch/en/view/90528617 Note Regards Christoph |
2 thankful Users |
12/15/2015 10:04 AM | |
Posts: 1529 Rating:
I assume you are using x150 as the system bus. What happens if you plugged into that instead of x130? |
