2/19/2013 10:38 PM | |
Joined: 9/27/2006 Last visit: 5/31/2023 Posts: 12028 Rating:
Hello r_guareschi; How much data do you exchange between the CPUs and the drives, what size telegrams do you use? There is a limit of 244 bytes OUT/244 bytes IN for the configuration of a Y-Link, as it is seen as a single Profibus-DP slave, as seen by the redundant CPUs. The following discussion should c;arify this issue: Y-Link calculation if this does not resolve your problem please give us some screencaptures of your problem with a more defined description. Hope this helps, Daniel Chartier |
2/20/2013 10:00 AM | |
Joined: 1/28/2006 Last visit: 4/18/2023 Posts: 11 Rating:
diagnosys |
2/20/2013 10:01 AM | |
slave diag |
