6/30/2010 9:00 AM | |
Posts: 73 Rating:
Hello, I think option B would work fine. You will have to configure the S7-300 PLC as a DP Slave over the Y-link Master System. You can do this by inserting appropriate GSD file for your S7-300 CPU. Please refer the link belowto download theGSD file for your CPU. S7 CPU GSD Download Refer the below FAQ for procedure to configure S7-300 as DP Slave on Y-link S7-300 CPU as DP Slave Hope this helps !! Thanks & Regards, Krrish !!! |
