7/8/2008 4:53 PM | |
Joined: 6/10/2008 Last visit: 9/15/2023 Posts: 158 Rating:
Hello, it would be good to post that datasheet and explains exactly what is bothering you. Did those experts tell you what gauge transmitter actually measure? For your application, it is fairly easy. You can use simple differential transmitter like shown in the attched file. On "+" side of transmitter, pressure is rho*g*level+at_pressure, while on "-" side is at_pressure. Since transmitter measure difference, it will actually measure hydrostatic pressure: rho*g*level. According to my knowledge, gauge pressure is defined like pressure defined to atmospheric pressure. Now it is arguable what is meant under atmospheric pressure? Is it normal atmospheric pressure of 1 atm = 1.01325 bar or "ambient pressure". Ambient pressure depends on height and temperature. AttachmentHydrostatic.pdf (319 Downloads) |
