7/13/2015 6:28 PM | |
Joined: 10/11/2006 Last visit: 2/2/2023 Posts: 5411 Rating:
Hello Sbartoc, an absolut encoder needs to be adjusted once and then the adjustement must be stored in the ROM. The resolver axis needs to be homed / referenced every time after being turned on. There are different methods to home an axis. You can simply just set the reference point or you can start different functions which will cause the axis to travel to any kind of mark. Please have a look in the S110 or easy positioner manual to read more about homing: https://support.industry.siemens.com/cs/de/en/view/109477922 |
With best regards, |
