2/15/2022 9:54 AM | |
Joined: 10/11/2006 Last visit: 7/26/2024 Posts: 5880 Rating:
Hello wellzbt, |
With best regards, |
2/16/2022 12:24 PM | |
Joined: 3/27/2008 Last visit: 7/29/2024 Posts: 1128 Rating:
The V20 manual does not give a good instruction for load monitoring, and because the MM440 is using the same parameter numbers I have attached a drawing for 'load monitoring', which should give you an idea of what is going on. Come back if I can help further with this. https://cache.industry.siemens.com/dl/files/529/24294529/att_77514/v1/440_OPI_24294529_en_1006.pdf page 223 refers. Tractor AttachmentLoad monitoring.pptx (317 Downloads) |
Last edited by: Tractor at: 02/16/2022 12:33:11Last edited by: Tractor at: 02/16/2022 12:57:27Tractor |
