9/20/2016 6:40 PM | |
Joined: 9/27/2006 Last visit: 10/8/2024 Posts: 12284 Rating: (2685)
Hello girl; There is a lot of information available to you through this site, you could try to explore it a bit, using the search box at the top right of this page. You will get manuals, FAQs, downloads, application notes, forum threads (that you can use filters on) and generally most of the answers you are looking for. For example, here are the CPU LEDs for S7-300 and S7-400 CPUs, taken from the following manuals (I found these using the search box, on "S7-300 CPU LEDs" for example): S7-300 CPU 31xC and CPU 31x: https://support.industry.siemens.com/cs/de/en/view/36305149 Simatic S7-400, S7-400 Automation system, CPU Specificationshttps://support.industry.siemens.com/cs/de/en/view/53385241 If you want to search for the LED information for S7-300 and S7-400 modules, I suggest you look for the S7-300 Module Data and s7-400 Module Data manuals. You should also look at chapter 23 of the "Programming with Step 7, v5.5" manual (look for it the same way). It shows how the diagnostic data of the PLCs is collected and available in the diagnostic buffer, a very useful tool for debugging a Siemens automation system. Hope this helps, Daniel Chartier |
9/21/2016 9:08 AM | |
Posts: 4 Rating: (0) |
thank for support ! have a nice day for you ! i try it on |
