8/13/2015 11:46 AM | |
Posts: 7 Rating:
Hi, I have the same problem. You said to use a memory card, I used CPU 1511 and memory card with 12 mb. I don't know if I have to change the value somewhere? But I find an otherway, if the cpu is connected to internet you can use <script src="https://code.jquery.com/jquery-2.0.2.min.js"></script> If you're not connected to internet, you can also remove .js from the "dynamics fles area" but still put the file in your html directory As explainded here :first and last post https://forum.jquery.com/topic/plc-siemens-s7-1200-web-server Thanks |
5/24/2017 7:21 PM | |
Joined: 2/8/2017 Last visit: 3/15/2024 Posts: 87 Rating:
remove ".js" in the HW config of your User defined Webpages. see also the entry in front of your entry
Last edited by: RedCali at: 5/24/2017 7:21:52 PMLast edited by: RedCali at: 5/25/2017 10:26:18 AM |
