9/21/2013 5:00 PM | |
Posts: 55 Rating: (0) |
DEAR SIR PEGAIA i have two small problem 1-i activated pulse on Q0.0 i can change value-frequency,but i need to know the value,for read on screen i activated hsc,AND ID1000,but i dont understand where i can read this value in plc propriety,i put frequency,intern signal 2-pulse ctrl pwm,on pin ENABLE,after i close conectionM100,still remain memorized,why? if i usephysique switch,extern,work--what happend plase take a loke on this zip thank you for solution
AttachmentMain (OB1).pdf (276 Downloads) |
Last edited by: O_Moderator at: 10/15/2013 9:45 AMnew subject after splitting from /tf/WW/en/Posts/89664#top |
9/21/2013 5:11 PM | |
DEAR SIR PEGAIA i have two small problem 1-i activated pulse on Q0.0 i can change value-frequency,but i need to know the value,for read on screen i activated hsc,AND ID1000,but i dont understand where i can read this value in plc propriety,i put frequency,intern signal 2-pulse ctrl pwm,on pin ENABLE,after i close conectionM100,still remain memorized,why? if i use physique switch,extern,work--what happend please take a loke on this rar thank you for solution
AttachmentMain (OB1).pdf (159 Downloads) |
9/21/2013 5:26 PM | |
hello i have this problem with hsc the module hsc in frequency is not active,why? thank you
10/3/2013 9:31 PM | |
DEAR SIR in my tia v12,258 is hw id,is one adress,is constant,i cant change this where can i put your value? hex? |
10/3/2013 9:47 PM | |
dear sir 258 is just hw adress,i cant change this you have other ideea,where can i put your hex? thanks
