9/9/2008 7:02 AM | |
Joined: 5/28/2008 Last visit: 5/23/2024 Posts: 4506 Rating: (836) |
I think you are still in designing phase and as you are planning to reduce the cost, Siemens has a low cost solution for driving stepper motors generally. You can use CPU224 and use its integrated fast outputs Q0.0 & Q0.1. Look also how to calculate and set the profile table, it is very important. You have to read in S7-200 manual in the section of PTO or Pulse Train Output how to program these outputs to generate pulses with high frequencies. These pulses are used to drive the stepping motors. AttachmentPulse Output instructions.pdf (198 Downloads) |
Ayman Elotaify |
9/9/2008 2:00 PM | |||||||||
Posts: 487 Rating: (44) |
Here are some I found in A&D mall.It may be from Sinumeric group. I do not know how compatible they will be for you. I know Sinumeric group has some cheaperCNC options using stepper motors.
