Industry Online Support
6/1/2007 7:29 PM | |
Posts: 1 Rating: (0) |
Is it possible to use combo boxes to select the trends that are viewed in the Trendview? If so, what is the best way to go about something like this? Thanks |
8/2/2007 5:48 AM | |
Posts: 15 Rating: (1) |
Hello Nemo! |
8/14/2007 2:18 PM | |
Posts: 220 Rating: (14) |
Hello Miz, perhaps this FAQ may help: http://support.automation.siemens.com/WW/view/en/21807421 its a description for tag multiplexing. so you will not change the trends itself, you change only the tag which is use for the trend. in this cluster also is an description for adress-multiplexing, maybe that this is more useful in this case. But to know which is better, needs to know how your configuration will be. greetings Aranel |
8/14/2007 5:09 PM | |
oops i've took the wrong link in first psot its the WinCC flexible with tag multiplexing. here comes the right one: http://support.automation.siemens.com/WW/view/en/24510668 sorry, hope i didn't confusing you too much ;) ´greetings Aranel |
