(0)| 1/16/2026 5:41 AM | |
Joined: 5/12/2006 Last visit: 1/16/2026 Posts: 22804 Rating:
not enough information download the panel image from sims and install it |
| 1/16/2026 5:51 AM | |
Joined: 1/21/2013 Last visit: 1/16/2026 Posts: 4405 Rating:
Hi martin_policer172, Install the V17 version of the panel image in your V20 TIA Portal to use with your SIMATIC WinCC Basic panel. On the download page, you will find the HMI PIU (Panel Image Updater), which allows you to select and download images individually. If you have trouble using this tool, follow the offline installation instructions in Section 1.2 instead. Kind regards |
| 1/16/2026 9:01 AM | |
Joined: 1/9/2026 Last visit: 1/16/2026 Posts: 4 Rating:
Thanks. Would it be this: HMI_PIU_Installer_2.0.0.0.exe (300,2 MB)(SHA-256) ? |
| 1/16/2026 9:03 AM | |
Yes, this is the installer file for the HMI PIU (Panel Image Updater). Kind regards |
| 1/16/2026 9:28 AM | |
Installed. But I saw only: My TIA: Still missing.. |
| 1/16/2026 9:30 AM | |
then install the panel images manually |
| 1/16/2026 10:35 AM | |
Joined: 7/31/2020 Last visit: 1/16/2026 Posts: 493 Rating:
Hello, On the following page, under the section: ‘1.2 Offline installation of Panel Images V17/V16 recommended for update’, you will find a PDF file describing how to manually install the panel images. Image Downloads for SIMATIC HMI Operator Panels: Comfort / Mobile / Basic Panels Best regards |
| 1/16/2026 12:52 PM | |
Success! Thank you and have beatiful day? ☺♥ |
