1/26/2022 10:58 AM | |
Joined: 2/8/2018 Last visit: 2/8/2024 Posts: 37 Rating: (0) |
Hi bergmanu, do you know if there's a way to define PLC variables in a dynamic way instead of writing them into the s7-in node? I would like to populate the variables list to read from a file, for example. Please let me know. Thank you very much for support. Fabio ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/27/2022 07:41:03New subject after splitting |
1/26/2022 11:12 AM | |
Joined: 4/28/2015 Last visit: 5/15/2024 Posts: 3345 Rating: (377)
Hi, I don't know a way to read out the variables dynamically. You use a file to create the list of variables, but only when configuring the s7-node. I couldn't find any hint in the nodes documentation whether this can be done dynamically during runtime. Same for defining which variable to use, I couldn't find a specific message you can send to the node to define the variable. Maybe that's a good question for the s7 node developers on github. Best regards! |
1/26/2022 2:58 PM | |
Thank you bergmanu. I will try to check with github developers. |
