7/24/2024 11:49 AM | |
Joined: 8/3/2009 Last visit: 10/28/2024 Posts: 14054 Rating: (1763)
Hello Willybong you can try to delete the temp data: https://support.industry.siemens.com/cs/de/en/view/109763043 If this will not work and the message do not appear in a new project then It could be that there is some damage in your proect. you should contact the technical support to check Bye Murof |
