8/15/2025 2:30 PM | |
Joined: 9/27/2006 Last visit: 9/18/2025 Posts: 12413 Rating:
Hello; Maybe you should consider upgrading the firmware of your "spare" CPU so it maches the frimware of the CPU yoi need to replace? https://support.industry.siemens.com/cs/ca/en/view/109474703 Hope this helps, Daniel Chartier |
8/17/2025 2:50 PM | |
Joined: 8/15/2025 Last visit: 9/18/2025 Posts: 7 Rating:
Thanks Daniel Chartier, I have found the “Download Operating System Updates V4.5H CPU412-3H / CPU414-4H / CPU414-4H PG / CPU417-4H ” and will follow the procedure for upgrading firmware from 5.2 to 5.6 step by step.. not able to do from 5.2 to 5.6 I understand. https://support.industry.siemens.com/cs/de/en/view/109474703 I have received two file for the Diagnostic buffer of module CPU 417-4 H for both Rack 0 and Rack1 in txt format. Will go to Classic forum to attach for review and advice. I am listing the errors that have occurred since the 11th August 2025 to 16th August 2025 for now to gain a better understanding of what the sequence of event are. The history of issues however started way back in 2023.. lol |
Last edited by: Moderator_Lan at: 08/18/2025 07:59:52link optimized Colin Canham |
8/17/2025 2:52 PM | |
AttachmentPGS_A.txt (67 Downloads) |
8/17/2025 2:57 PM | |
PGS_A.txt is the Diagnostic buffer of module CPU 417-4 H for Rack 0 the next attached PGS_B.txt is for the Diagnostic buffer of module CPU 417-4 H for Rack 1
AttachmentPGS_B.txt (70 Downloads) |
Colin Canham |
