(0)| 12/7/2011 9:30 AM | |
Joined: 4/29/2010 Last visit: 1/20/2025 Posts: 1557 Rating:
Hello, first of all i would check the cable. At this FAQ you can find the correct pin assigment for serial cable wich is needed: What is the serial cable assignment for transferring the configuration to an RMOS operator panel? And also the caused wich are described at this FAQ: Why is the connection interrupted while transferring a project with ProTool to an OP? best regards |
| 6/4/2014 4:10 PM | |
Joined: 9/1/2005 Last visit: 1/9/2026 Posts: 4114 Rating:
follow up question published by bourgetis split to a seperate thread with the subject OP7 Protool - instal this software Best regards CS Moderator |
