8/24/2010 3:15 PM | |
Posts: 206 Rating: (22) |
Hi GoForIT, yourproblem might be that you don´t read the data record (DR) 33. This DR contains the totalizers. To read this DR you have to use the command 233, each time you want to refresh the totalizers. You could extend the OB35 of the getting started projekt with the command 233. Regards ABenno |
8/24/2010 8:44 PM | |
Posts: 352 Rating: (7) |
OK It's not very clear to me when to write to cmd1, 2 or 3, but I found another way to send 233 to cmd2 and put it into OB32. That did the trick. Thanks.. Ola |
