12/2/2010 7:30 AM | |
Posts: 17 Rating: (0) |
Hi all! In my new project I am using the PID compact, so far works great, even the autotune, I only have one problem for which I have yet not found any solution. I'm trying to use manipulated value limits and I can specifiy the upper limit from 0 to 100%, while trying to change lower limit to anything different from zero I get Invalid value I've read that lower limit can't bee changed if using PWM output, but I chose Output as output parameter. Any suggestions ? Splitted from TIPS for PID (FB PID_Compact). |
Last edited by: O_Moderator at: 12/2/2010 1:30 PMnew subject after splitting Last edited by: PrimozV at: 12/2/2010 7:37 AMWhile playing around I found that the low limit can be changed to a negative value, why not positive ? |
