2/9/2012 6:17 AM | |
Joined: 8/31/2010 Last visit: 5/15/2024 Posts: 1510 Rating: (222) |
Using the MPI Port will not help you, you need a Point to Point Communication Processor (CP34x). Check this detailed documentation / application example on the same - Wireless Signaling and Switching via SMS with S7-300/400/ET200S Controllers and the MD720-3 GPRS/GSM Modem |
Like it? Rate it! |
3/5/2012 2:28 PM | |
Hello mayur_101988, Check this Application example on Wireless Data Communication based on GPRS with S7-200 You can make use of this code to connect to the SINAUT Micro SC Server. Hope this helps |
Like it? Rate it! |
