8/11/2012 10:53 PM | |
Joined: 5/12/2006 Last visit: 7/15/2024 Posts: 22308 Rating:
Hello, yes for Integration you need Drive ES. Which OS and which Step7 Version do you use? Regards Christoph |
8/12/2012 4:32 PM | |
Hello, here http://support.automation.siemens.com/WW/view/en/18495518you can show which DRIVE ES Version is compatible with your SW. You should use Drive ES V5.5. But you must install DriveES befor starter, so remove Starter V4.2 and then install Drive ES (Starter is included in Drive ES). When Step7 , DriveES and Starter ist installed you don't need a gsd File for the SINAMICS drives. Regards Christoph |
