11/10/2005 8:22 AM | |
Posts: 3149 Rating: (171)
Hi Shamsher, there is a quite nice tool for modifying your tags: http://support.automation.siemens.com/WW/view/en/22016422 This tool will not be installed automaticly with wincc => START > settings > control panel >add remove programs > wincc > add component Or you use the WinCC configuration tool (please have look at the WinCC help), this isn´t installed automaticly as well Good luck, Nemo |
