4/24/2014 2:54 PM | |
Joined: 10/11/2006 Last visit: 8/12/2024 Posts: 5889 Rating: (802)
Hello, are you sure that your spare motor is indicating the same MLFB? The second digit of secondblock ofMotor-MLFB indicates the encoder. 1PH7103-2PD02-0BA0 P = DQI resolver 14bit Actually,regarding commissioning, itshould be independent on internal used resolver as long as MLFB is indentical. What is the fault number or errormessage CU is showing? In case of a serious motor problem you can contactservice support via online contact: https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=de&objid=38718979&caller=view |
With best regards, |
