9/25/2014 2:01 PM | |
Posts: 4 Rating: (0) |
No this is not turned off. |
9/25/2014 3:16 PM | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Joined: 1/5/2011 Last visit: 6/15/2024 Posts: 815 Rating: (122) |
Dear John, Ok, first of all turn on standard block acces ( or turn off optimized ;) ),now if this is all you have and you wrote your code correctly it should work... you see were I'm going? If we can't take a look at your code or a snippet of it, then we can't know what's wrong with it. What language are you programming in, I'd assume SCL? Are you working with indices combioned with a array? If that's the case, check out:
Are you using an ANY pointer? Are you having problems settings up your ANY pointer? Check out:
Are you using BLKMOV to transfer content from one memory area to another? Check out:
Is this of any help for you? If you want a more targetted answer, please share usthe snippet of your code were the error occurs. Kind regards, Jens |
