3/1/2008 6:37 AM | |
Joined: 9/27/2006 Last visit: 6/3/2024 Posts: 12259 Rating: (2670) |
Hello PLC Engineer; If you are going to use ET 200M modules (S7-300 I/O modules on a IM 153-2 Profibus interface) then there are 3 relay DO modules you can use: 6ES7 322-1HF00-OAB0 6ES7 322-5HF00-0AB0 6ES7 322-IHF10-0AB0 You con find information on all S7-300 I/O modules in this manual. For the S7-400 family, you can use this module: 6ES7 422-1HH00-0AB0 Info on the S7-400 I/O modules can be found here. Hope this helps, Daniel Chartier |
