7/1/2016 3:12 PM | |
Joined: 11/21/2007 Last visit: 7/7/2024 Posts: 2325 Rating:
Hello You should be able to connect with a standard USB to Mini USB cable. The following FAQs provide more information : STARTER: Why does the USB connection with SINAMICS G120 not take place? SINAMICS G120/G120D/G120P (CU 2x0x) and G120C: How can I go online with an existing STARTER project, via USB interface? If still you face a problem, try to use another cable / another PC Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
7/5/2016 5:09 PM | |
Posts: 18 Rating:
Hi Thank you for the help. I am using a USB3.0 port on my laptop. Is this the issue? |
7/6/2016 6:48 AM | |
Joined: 5/12/2006 Last visit: 7/16/2024 Posts: 22316 Rating:
Hello, this can be the issue, please check it with a USB2.0 Port.
Christoph |
