3/8/2006 1:24 PM | |
Posts: 3149 Rating:
Hi, well, VBS is not my programming language... In C it´s quite simple, you´ve got in WinCC Graphics Designer a DynamicWizard for "Picture exchange in workspace", based on SSMChangeWorkfield: http://support.automation.siemens.com/WW/view/en/19224474 Nemo |
3/8/2006 1:47 PM | |
Posts: 3149 Rating:
Hi Take WinCC picture windows, then it´s very simple [:D]. nemo |
3/8/2006 3:48 PM | |
Posts: 17 Rating:
[quote user="Nemo"]Hi, well, VBS is not my programming language... In C it´s quite simple, you´ve got in WinCC Graphics Designer a DynamicWizard for "Picture exchange in workspace", based on SSMChangeWorkfield: http://support.automation.siemens.com/WW/view/en/19224474 Nemo Hi Nemo, Using your above reference I have made a popup screen that does ALMOST what I want. (C not being my programming language... ;-) But I cannot find a command that CLOSES the popup screen after the operator has clicked on a button there. (After exceuting the SSMChange... I want to execute a command that closes the message window) Can you help me with this also? Best regards Henrik |
3/8/2006 4:35 PM | |
Posts: 3149 Rating:
Hi, did you use the picture window? Then set the property > miscellaneous > display of this picture window to "no", either by script or connecting this property to a variable/tag. http://support.automation.siemens.com/WW/view/en/11868924 nemo |
