4/24/2020 7:42 AM | |
Joined: 4/25/2017 Last visit: 10/11/2024 Posts: 430 Rating: (66) |
Hi, And now i have another solution: Because the MQTT-Library is not for S7-1200 with TIA V13 you can use a little Gateway: SIMATIC CloudConnect 7. An Application Example is under following link: Unfortunaley the Example does not explain IBM Cloud but following the manual of CC7 it should work. |
Best Regards, |
4/24/2020 7:27 PM | |
Posts: 11 Rating: (0) |
thank you so much for your answer !! |
